Just Cause 2
Publisher: Eidos
From our
Just Cause 2 review:
What makes Just Cause 2 shine is the fact that players are innately anarchic and that the weapons function as a toolbox for embracing that – not the level of polish with which the game has been assembled.
There are far better story driven shooters out there if you’re primarily interested in fighting, but if you’re willing to step away from the beaten path though and motivate yourself to see what Just Cause 2 has to offer then you’ll have a lot of fun. It’s far better to be driven by the curiosity of what’s on the next island than the barked orders of a Texan stereotype and it's far more fun to spend time messing around with the grappling hook than actually trying to follow the storyline.”
We run the game at its maximum graphical settings, with motion blur disabled. GPU water effects and the BOKEH filter are disabled as these are Nvidia exclusive graphical options. A 60 second FRAPs run is taken from within the Concrete Jungle in-game benchmark.
        AMD Radeon HD 5970 2GB
        Nvidia GeForce GTX 580 1.5GB
        Nvidia GeForce GTX 480 1.5GB
        Nvidia GeForce GTX 570 1.3GB
        AMD Radeon HD 6970 2GB
        AMD Radeon HD 5870 1GB
        AMD Radeon HD 6950 2GB
        Nvidia GeForce GTX 560 Ti 1GB
        AMD Radeon HD 6870 1GB
        AMD Radeon HD 5850 1GB
        AMD Radeon HD 6850 1GB
        Nvidia GeForce GTX 470 1.2GB
        Nvidia GeForce GTX 460 768MB
        Nvidia Geforce GTX 460 1GB
        AMD Radeon HD 5770 1GB
          20
          30
          40
          50
          60
          70
          80
    Frame Per Second
    Frame Per Second
    Frame Per Second
    Frame Per Second
        ATI Radeon HD 6850 1GB
    Frame Per Second
    Frame Per Second
For explanation of what these numbers mean, head to the
Results Analysis page.
